Formula for rolled up conveyor belting
I was wondering if anyone has a formula for figuring out the length of a conveyor belt rolled up on a spool.
RE: Formula for rolled up conveyor belting
Here's one I found, I can't tell you if it works or not...
Belt length in feet = A x number of coils x 0.131
A = Diameter of coil in inches + Diameter of coil hole in inches
L = (3.14/2T)(od-id)
where
T is thickness of each layer
L is length of roll
od = outside diameter
id = inside diameter
Use consistent units and conversion factors.
I use this one and it works all the time.
L = NS X .2618
Where L = length
      N = Number of turns on belt
      S = Measured inches between ends on roll of belt
