SW Configuration Check
I have a part with 180 configurations.
Is there a macro available which will run thru all the configurations and give a list in case there are errors in any of the configurations?
RKam
RKam
RE: SW Configuration Check
Another way to check is to create a new design table. A new design table wil automatically detect all config-specific parameters.
CODE
Dim swDoc As SldWorks.ModelDoc2
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swConfig As SldWorks.Configuration
Dim swConfigs As Variant
Dim swFM As SldWorks.FeatureManager
Dim swFeat As SldWorks.Feature
Dim i As Long
Dim sMsg As String
Dim Wait As Long
Dim errCnt As Long
Dim bHadErr As Boolean
Sub main()
Set swApp = Application.SldWorks
Set swDoc = swApp.ActiveDoc
Set swConfigMgr = swDoc.ConfigurationManager
swConfigs = swDoc.GetConfigurationNames
Set swFM = swDoc.FeatureManager
sMsg = "Errors found in configurations:"
swDoc.Visible = False
On Error GoTo SEEMEAGAIN
For i = 0 To UBound(swConfigs)
swDoc.ShowConfiguration2 swConfigs(i)
'Debug.Print swConfigs(i)
Set swFeat = swDoc.FirstFeature
bHadErr = False
errCnt = 0
While Not swFeat Is Nothing
If swFeat.GetErrorCode <> swFeatureErrorNone Then
bHadErr = True
errCnt = errCnt + 1
End If
Set swFeat = swFeat.GetNextFeature
Wend
If bHadErr Then
sMsg = sMsg & vbCrLf & swConfigs(i) & " - " & errCnt & " error(s)"
End If
'Wait = Timer
'While Timer < Wait + 1
' DoEvents
'Wend
Next i
If Right(sMsg, 1) = ":" Then
MsgBox "No configurations had errors."
Else
MsgBox sMsg
End If
SEEMEAGAIN:
swDoc.Visible = True
End Sub
-handleman, CSWP (The new, easy test)
Anyhoo, beware the API call "ConfigurationManager::GetConfigurationParams" that lists the difference between configs. It misses a lot. As I recall, it does not list config-specific suppression states.
Your Macro was exact and works wonderfully.
Is there a macro available which will run thru the configs and we are able to see the model updates as it goes thru the configs.
CODE
Dim i As Long
Dim sMsg As String
Dim errCnt As Long
Dim Delay As Double
Dim Wait As Double
Sub main()
'swDoc.Visible = False
Delay = CDbl(InputBox("How long would you like to display each config. in seconds?"))
Wait = Timer
While Timer < Wait + Delay
DoEvents
Wend
bHadErr = False
errCnt = 0
bHadErr = True
errCnt = errCnt + 1
End If
Wend
If bHadErr Then
End If
'Wait = Timer
' DoEvents
'Wend
Next i
Else
MsgBox sMsg
End If
SEEMEAGAIN:
'swDoc.Visible = True
End Sub
This was a very good one, more than what I wanted, with the time setting for each config view. Very useful, though I did not think of this when I asked you this.
Excellent, Thank you very much!!!
I totally agree - Sooperb Handleman!
It's a very useful time saver for those that use (or administer) configurations. I'm sure it would be used by many. You should finish it and post it.
Thanks rkam for asking about this.
Tobin Sparks
www.nov.com
What sort of finishing do you mean? Additional functionality?
It already functions better than expected
Thanks Again
Tobin Sparks
www.nov.com
There's really not much here that hasn't been posted in previous threads. I think the bulk of the config changing code came from some example in the API help.
Okay - thanks for putting this together for us. ""I don't really "post" stuff anywhere but here"" - maybe this could go in FAQ.
Thanks Again
Tobin Sparks
www.nov.com
