Surcharge load is 1.2m away from retaining wall
I try to design a retaining wall with surcharge load of 80Kpa. The surcharge load is 1.2m away from the wall and the wall is 1.8m high. The base is 400 thick, the key is 400 high.
When I check the sliding, I end up the base of 3.5m long when I use horizontal load due to 80KPa surcharge applied to the full hieght of retaining wall.
My question is that I am right when I applied the full horizontal load due to 80KPa surcharge applied on the full height of the wall or I should project the line of 45 degree under surchagre load and apply the horizontal load which start from the intersection of the line and wall to the base. Therefore, I can end up the base to 2.3m (small sliding load now)
RE: Surcharge load is 1.2m away from retaining wall
If the width of the base is driven by the load to the heel to resist sliding, consider putting a vertical key below the footing to help take the lateral.
Mike McCann
MMC Engineering
The hard thing is when using Boussinesq, you can project 45 degree line down and applied the lateral loading below that. This method is suggested from a senior structural engineer.
Another method from US Army Corps of Engineers "Retaining and Flood Walls", we use full lateral pressure applied to the wall. Thus is suggested from a senior geotechnical engineer.
Surcharge load of 80KPa is 1.2m away from the wall give lateral loading of 21KN using Bousinesq and 27KN using Tezaghi.
I think Bousinesq method is a common way using of the engineer. Tezaghi which is suggested by geotechincal engineer, is likely more accurate to use.
