Bolt Edge Distance
Bolt Edge Distance
Different edge distances are allowed depending on what type of edge is present on the steel (per AISC, AASHTO, AREMA, etc.). There are 2 classes, 1 is rolled or thremally cut, the other is sheared. My question is what about edges that have been sawed. To me sawing steel would be the same as rolled and thermally cut because the damage to the steel is not like when the steel is sheared, but that is just my guess. What do others allow/think......
RE: Bolt Edge Distance
Is thremally cut in the same class as sawed then?
On the other hand, it could be argued that saw-cutting is a form of shearing. I'm inclined not to argue that, but I could be persuaded.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
The 3 classes by AS4100;
1. sheared or hand flame cut
2. machine flame cut, sawn or planed
3. rolled edge
With edge distances equal to 1.75, 1.5 & 1.25 x bolt dia respectively.
