Is plate heavier than billet?
If you were to have 2 exactly shaped/sized pieces out the same material except one came from a plate and one came from a solid block of aluminum.
Would they weigh the same?
SW2008 Office Pro SP3.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot/SpaceNavigator
RE: Is plate heavier than billet?
Basiclly if they have the same density, then they should be same.
2.2GHz, 2.00GB RAM
QuadroFX 3700
