Advice on A519 Weld Parameters
Our shop has been ordered to produce some special pipe fittings for a HP hydraulic application. The material is ASTM A519 grade 1045 or 1050 annealed condition.
The engineer has applied ASME B31.1 and/or B31.3 welding reqt's. I am certain this customer has applied these without knowing much about either Code, but such as it is I am bound to qualify a new weld procedure. The ASTM A519 fittings will be joined (buttwelded) to A106 Grade B, 4"NPS Sch 80 pipe.
The high carbon content of 1045/1050 has me concerned and am uncertain of what an appropriate post weld stress relief, if any.  I expect my general WPS to look like this:
GTAW root  using 80s-B2 or B2L
SMAW fill using 8018-B2L or B3L
Open butt with Backing gas or backing ring (not sure which at this moment)
Preheat: 350-400 deg F
Interpass: 600 deg F
Stress relief: 1100 degrees for 30 mins
Key questions if you please:
1.    If stress relief is necessary,  does it matter if the welds cool too room temperature before pwht?  I may not be able to get weldments to a high temp stress relief quickly. Comments please.
2.     Not sure why I am selecting 80x wire and rod other than to match strength of the Gr1045 fittings.
3.    Why do you suppose AWS B2.1 does not list A519 grade 1045/1050 but it does list other heat treatable alloy such as A519 Grade 4130?
Thanks again for all ideas & comments.
RE: Advice on A519 Weld Parameters
tc7;
PWHT must be performed because of the increased carbon content in 1045 CS. No, cooling to RT is permitted provided low hydrogen wire or weld rod is used.
Agree
