Decimal places required for angles
Using Y14.5 and decimal inch on drawing, how should an angle of say 25.000 (basic) degrees be expressed. How many decimal places are required?
The Standard seems to be a little vague or again I am overlooking.
RE: Decimal places required for angles
are used, both the plus and minus values and
the angle have the same number of decimal places.
EXAMPLE:
25.0° ±.2° not 25° ±.2°
Supposing 6 holes at 60 degrees, with a positional tol of .005 dia. Is the angle required to have 3 trailing zeroes? Again by the Standard?
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - Thomas Jefferson
KENAT, probably the least qualified checker you'll ever meet...
