convert to m, not mm? (also, chg units in Sim to N, m not mN, mm)?
NX5.0.5
Advanced Simulation
Is it possible to convert a part to units of [m], not [mm]?  Also, is it possible to convert a part's "consistent units in simulation" from mN, mm (and mN/mm^2 etc) to N, m, N/m^2, etc?
This would be useful in interfacing with other simulation environments (such as Patran/Natran) where going convention is often N, mm, Pa, etc.
I've looked at ug_convert_part.exe but it only handles conversions between mm <-> in.
Help?
RE: convert to m, not mm? (also, chg units in Sim to N, m not mN, mm)?
...answering my own question:
to output simulation files (including mesh, along with material props, boundary conditions, etc), use
File > Export > Simulation
and then choose the appropriate units.  The resulting file will have the correct units (ie: N & m, rather than NX's "consistent units" of mN & mm etc).
Set the file extension to whatever is desired (ie: *.bdf if one wants to output an input file for Nastran)
