Create smart point in UG Open API/C
Does anyone know whats up with the Create smart point in UG Open API/C? I get errors when I try and compile any code using this option. It seems there is no support in NX4.
Does anyone have a working code snippet of point routine that they could share if they have solved this?
What I am looking for is a point that will hold its position on a curve if it is resized. I can do a smart object point but not one that will stay in the middle if for example a 2 inch line becomes a 4 inch line.
Thanks all!
RE: Create smart point in UG Open API/C
Smart object has dynamic update fuctions,not a iolated object.
I create a point on a surface with following code.It will be updated when the face changed  .
  Session theSession = Session.GetSession();
            try
                Feature pnt = null;
                PointFeatureBuilder theBuilder = theSession.Parts.Work.BaseFeatures.CreatePointFeatureBuilder(null);
                NXObject sel;
                Point3d cursor;
                if (UI.GetUI().SelectionManager.SelectObject("", "",
                    Selection.SelectionScope.AnyInAssembly, true, new Selection.SelectionType[] { Selection.SelectionType.Faces },
                    out sel, out cursor)
                            == Selection.Response.ObjectSelected)
                    Face theFace = sel as Face;
                    if (theFace != null)
                        //UI.GetUI().NXMessageBox.Show(null, NXMessageBox.DialogType.Information, theFace.ToString());
                        Scalar u = theSession.Parts.Work.Scalars.CreateScalar(0.5, Scalar.DimensionalityType.Length, SmartObject.UpdateOption.DontUpdate);
                        Scalar v = theSession.Parts.Work.Scalars.CreateScalar(0.5, Scalar.DimensionalityType.Length, SmartObject.UpdateOption.DontUpdate);
                        theBuilder.Point = theSession.Parts.Work.Points.CreatePoint(theFace, u, v, SmartObject.UpdateOption.AfterModeling);
                        theBuilder.Commit();
Nicholas (Kun Jiang)
PhD. Candidate,SJTU.
