In SW how do you put a section view on a different sheet?
When creating a section view, I want to put it on a different sheet than the original section view. I can put it anywhere on the sheet that has the first view, but I cant seem to get it on to another sheet.
Advice?
Advice?
RE: In SW how do you put a section view on a different sheet?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
It will remain linked to the original sheet.
James Spisich
Design Engineer, CSWP
Right click on the section view
Select alignment
Then break alignment.
thanks again.
