High Speed-High Power Coupling Manufacturers
We have just discovered a crack in the windage shroud in a 40MW 4000rpm coupling (turbine-gear)  As always the OEM has quoted some 20 weeks delivery. In a previous job, circa 2003 I bought a 'copy' coupling from a firm in the USA on a much shorter turn time but it carried a hefty price tag.  I have since moved jobs twice and lost the contact details.
Does anyone know who I might have dealt with? Does anyone know of an alternative supplier?
Andrew
RE: High Speed-High Power Coupling Manufacturers
I found the info,  FlexElement in Texas.  Anyone any recent experience f them?
AD90
Thanks, I am aware of the big-boys in the coupling world, but they tend to have longer lead times.  I made contact with the guys on my previous project.  They have never used the couopling that was bought from FlexElement so I have no feedback.
AD90
If you want a full API671 coupling with all its documentation requirements you need to accept the 20 week delivery quoted however if you are in a position whereby you need to run your equipment and will to accept the coupling without all the API 671 requirements I would guess the delivery can come down.
Dont take any short cuts with these couplings would be my advie.
