Saturated soil pressure on Tunnel Portal
I have a situation where there is a 10m deep, 2m diameter soakaway on the top of a Tunnel Portal with a water proof membrane capable of taking only 2 bar pressure. The Tunnel is approximately 70m below the Soakaway. The soil is made of Chalk. The question is will the membrane sustain the water pressure? If so what is the method of calculating the actual water pressure on the Tunnel Membrane.
Ak
Ak
RE: Saturated soil pressure on Tunnel Portal
roger
