Taper Threads
Taper Threads
Ive added a hole, threaded hole and a tapered hole.
Is there anyway of adding a Taper Thread i.e. NPTs ??
TIA
TIA
Milkboy
RE: Taper Threads
As far as I know there is no way to create a tapered hole, like an NPT, using just the thread command. If anyone has an easier way to do this please speak up.
RE: Taper Threads
In v10; there are a picture when I inserted a thread, for this is necessary activate view colors in part
RE: Taper Threads
I do currently run v10 and have not figured out how to do this other than the way I described.
Could you give a step by step on what you do. I am sorry to say that I am having a hard time following your post to figure out what you are doing.
RE: Taper Threads
Could you show me an example of how you create threads in SE with VB?
thanks
Mlody
