Nutplates
Nutplates
Has anyone a helpful tip where to find nutplates catalogs (to be used for aircraft)?
RE: Nutplates
SPS has a catalog of standard fasteners (it produces) that has proven to be a helpful "finder" for me. I then go to IHS specs-standards for the actual data.
http://www.spstech.com/aero/prod_lit/index.html
Down load the "Aerospace Fasteners (7.5MB PDF file)
Numerical Listing of Parts. Lists NAS, NA, AN part numbers for aerospace bolts, nuts and washers" brochure.
The noted brochure has a little pictorial view of most current generation NAS, MIL, MS etc fastenerss... and enough of a description to be a useful starting point.
Regards, Wil Taylor
RE: Nutplates
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - Thomas Jefferson
RE: Nutplates
Give this a shot -
Alcoa bought out a lot of fastener companies, including Kaynar.
RE: Nutplates
RE: Nutplates
Just for completeness, where do you get the ESNA nutplate detail information from? IHS site doesn't recognize them.
RE: Nutplates
ESNA was bought by MacClean Fogg, which has a crummy website. I was able to find a catalog at
http://www
It includes the ESNA clinch nuts as well as their other products.
RE: Nutplates
RE: Nutplates
http://assist.daps.dla.mil/quicksearch/
You can actually find alot of governement published documents here. So stuff like NAS/MS/AN/NASM.
You can also try:
http://www.alldatasheet.com/
RE: Nutplates
TA2507 ANCHOR, FLOATING, CORNER,
CAPPED, BASE SEAL
10-32 thru 5/16-24 to 250°F
Regards, Wil Taylor
RE: Nutplates
http://www
RE: Nutplates
Bad news: one of my replies appears to have been trash-canned [disappeared].
Further options to consider.
FTI ForceTech rivetless nutplates. Sealed version is available. Elegant solution! NP base is sleeve-cold worked into position like forcemate bushing [obvious fatigue benefits]; and a replaceable Nut element is installed. http://www.fatiguetech.com/fasteners_forcetec.html
NAS1735 Elliptical Blind nutplates are [were?] extensively used in F-16 wings. Install NAS1735 per NAS1736.
Click-Bond adhesive bonded nutplates [seal version available] http://www.enfasco.com/Click2I.htm
Regards, Wil Taylor
