Inputting Data
Inputting Data
I want to use equations that use data from a table (on the same worksheet would be nice)
So how do I go about it. Imagine my equation for a certain model is 2 x A, where A is situated in the data file (row?) and depends on what type the base model is.
(I can't seem to find what I want in the help files or by using search. I'm probably using the wrong terms)
RE: Inputting Data
RE: Inputting Data
RE: Inputting Data
The attached file computes: Y = A + B*t + C*t^2 + D*t^3
where A, B, C, D are different depending on the model (model1, model2, model3, or model4).
The values of A, B, C, D are stored in a table which is named "mtable" (named range).
The values are retrieved from the table using hlookup function.
= hlookup(mtable, lookupvalue, rownumber)
where the model is used as a lookupvalue. The hlookup finds the correct row for the model and reads down the number of rows you tell it to find the correct coefficient.
The second version (labeled "more elegant", but actually a little more complicated) uses match function to determine the correct row number for A, B, C, D)
RE: Inputting Data
Thanks again
