can you work as a control eng
Hello
iam a new mechatronics eng from egypt and my branch is analog to automation and robotic eng, i found that automation and robotic jobs in my country is limited in automotives centers and production lines in factories also can work in cad/cam field, but can an automation and robotic eng works in your countries as a control eng and deal with instruments, motors, solenoids etc or it is not
RE: can you work as a control eng
You need to work on your writing or you won't likely be working in the USA. You need to get the punctuation down a little better and you need to use Capital letters correctly or companies will move on to the next candidate.
Once you have that, and I think you can do it, there are certainly other places doing mechatronics and robotics! Semiconductor equipment makers have a lot of that in each machine. Look at companies like Applied Materials and Novellus.
Keith Cress
Link to these sites and perform searches. This will show you a survey of the jobs available, but certainly not all of them. There is a "hidden" job market out there with many unpublished positions available. But these sites will give a good initial survey.
www.monster.com
www.careerbuilder.com
www.indeed.com
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
TygerDawg
Blue Technik LLC
www.bluetechnik.com
