CNC router vs. Water jet cutting for 1/2 inch plywood
Intricate cutting of pattern in 1/2 inch (4x8 ft)plywood sheets required, any recommendations as to best method?
RE: CNC router vs. Water jet cutting for 1/2 inch plywood
Figure the router has to use a bit at least .25" diameter; the water jet's equivalent is less than a tenth of that.
Mike Halloran
Pembroke Pines, FL, USA
http:/
just think dot matrix from a distance :)
Cnc routers can generally cut at about 300 to 450 inches per min depending on thickness and diameter of cutter used
Water jet cutters cut sharper inside corners , your choice.
B.E.
