Code Case 2235-9, Use of UT in lieu RT
Hi Everybody,
According to Code Case 2235-9, (C) state that "The qualification block(s)shall be prepared by welding or HIP......,oriented to simulate flaws parallel to the production weld's fusion line... "
Question 1).The qualification block(s) shall be contain with a welded joint?
Question 2). If the qualification block(s) contain a welded, done welded joint configuration shall be same with production vessel...?
Million thank
RE: Code Case 2235-9, Use of UT in lieu RT
This has been answered already. Please search in this forum.
Metengr,
Thanks for you reply. Do you have a guide (with detail)how to make flaws in welded?
2468jjcr;
The flaws can be introduced by using EDM notches and flat bottom holes.
