Buried pipe load bearing capacity calculations
Does anybody know where to find information on calculating the allowable pipe loads or capacity of buried pipes? Are there any comprehensive resources on calculating the capacity of pipes of all types (hdpe, pvc, steel, clay, etc.)?
Thanks!
RE: Buried pipe load bearing capacity calculations
There are many sources, but I don't know of a single source that answers all of your questions.  Start by looking through such sources as pipe handbooks, State Highway Department design manuals, and your old textbooks.  Many of these are on line so Google them ( Google is now a verb but Giggle is not.)
good luck
Check out this website.
http://www.uni-bell.org/literature.php
all of the materials listed here are available in book form as well.
Talk to your PVC Pipe Rep.
I think ductile iron pipe design is covered in one of the AWWA standards.
the uni-bell.org pvc pipe design manual only contains 6 pages.
But does anybody know of direct sources to such buried pipe design manuals? Do any of the AWWA manuals contain such information?
cvg those are great links!
"But does anybody know of direct sources to such buried pipe design manuals? Do any of the AWWA manuals contain such information?"
Yes and yes.
AWWA Manual M-11 Steel Pipe.
In all buried pipe types, the backfill type and quality is crucial in the capacity due to the soil/pipe interaction.
Download Australian standard AS 2566.1 Buried Flexible Pipeline Design. This gives you clear advice as to how to determine the loads and the deflection,stres, strain, buckling and combined loading criteria.
Also Structural Mechanics of Buried Pipes by Watkins is a good reference. Also Buried Pipe Design by Moser should be a considered text.
