Rigid surface
Rigid surface
I am trying to model a pipeline laying on a rigid surface to do some analysis. I have model my rigid surface as 3D analytical rigid. However, when run the analysis the pipeline goes through the rigid surface.
How can I make it no to go through and act as a solid ground.
RE: Rigid surface
RE: Rigid surface
Martin Stokes CEng MIMechE
RE: Rigid surface
what do you mean by Interaction module?
can you please explain how can I set that?
I am modelling it as 3D analytical rigid so there is no need to mesh or spcify material properties.
RE: Rigid surface
If you are writing the input file some other way, then you need to make sure that there is either a *CONTACT PAIR definition or *CONTACT (Explicit only).
ABAQUS will not 'assume' there is contact - you have to specify that there is contact.
RE: Rigid surface
