rated current of overhead line
Hi All,
i am working on a very basic simulation of the transmission network in spain and the impacts of a rising share of wind energy. In Spain, they operate with 220 and 400kV overhead transmission lines.
I couldn't get information on the current capacities, but i do need the rated current to proceed with my simulation done with DIgSilent/Power Factory. They vary from line to line, but an estimation that covers the average would realy help.
I am thankfull for every link and reference.
Have a nice weekend,
heinz
heinz
RE: rated current of overhead line
You really need to get in contact with the owner/operator of those lines to get the right information, although I suppose you could look at it at the extremes (above may be a decent starting point), and check those. If it ends up ok at both ends, it probably would be ok in the middle...at least for a first look WITHOUT all of the necessary data to do it right.
As indicated by Overvoltage, there are many factors that go into determining the rating. The thermal rating in the link is one, but the temperature limit may be different. The line may be limited by stability criteria as well as thermally.
Welcome to Eng-Tips HeinzS.
And a belated welcome to Overvoltage.
Keith Cress
JIM
Bill
"Why not the best?"
Jimmy Carter
765 KV line having 4 X 686 sq. mm
conductor -2250 MW per circuit.
765 KV line having 4 X 686 sq. mm conductor
operating at 400 kV -614 MW per circuit.
400 KV line having 2 X 520 sq. mm conductor
with shunt reactor - 410 MW per circuit.
without shunt reactor - 533 MW per circuit.
operating at 220 kV - 155 MW per circuit.
220 kV line - 132 MW per circuit.
132 kV Line - 50 MW per circuit.
Your posts give me a fist hint, but i guess that the net operator is the only one who could give me a satisfactory figure.
If anybody of you know anybody working with or at the spanisch net operator REE (Red Electrica Espana www.ree.es), i would realy appreciate to get in touch with a contact person over there. Because right now, i didn't receive any answer writing at redelectrica@ree.es.
Best
Heinz
