Dust Free Friction Material Needed
BACKGROUND: I am enhancing a proprietary moldless casting machine that centrifugally casts a near-perfect coating on a curved surface. The degree of perfection inversely depends on the variation in angular velocity. A servo motor drives the unit through a 100-to-1 gear speed reducer.
PROBLEM: Backlash in the gearing prevents the servo drive from maintaining a constant angular velocity.
PROPOSED SOLUTION: Provide a relatively small amount of parasitic torque in the form of a brake such that backlash is eliminated in the gearing.
NEW PROBLEM: After trying several styles of strap brakes, I've eliminated brake squeal by using a 3-1/2" 410 SS disc brake and a bicycle caliper. The current problem is DUST - this contaminates the surface of my cast workpiece. I've tried several commercial forms of disc pad compounds including Ceramic-Carbon Sintered pads which I incorrectly believed was dust free.
SOLUTION NEEDED: What type of brake pad material will emit the minimum of dust? And just as importantly, where do I get this material? I've tried the pads available from the caliper manufacture and they are VERY dusty.
Thanks in advance for your kind reply!
S.D.
RE: Dust Free Friction Material Needed
You need to stop looking at the friction materials used for vehicles - they are designed to behave just as you describe.
You can look at metallic parts, but there will be higher noise and vibration.  You may need to provide a lubricant at the surface, and you may need to provide cooling for the part.
Perhaps you can work on isolating the braking system from the casting chamber.  How about a vacuum or forced air system?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Electro magnetic retard?
Rod
I'm with Rod.
An electric field.
Look at engine dynos that use water brakes or eddy current brakes.
