SECTION VIEW-REMOVING SECTION SCREEN
When creating a section view, prior to clicking on the green check, is there a way to remove (or disable) the "graded screen" (which looks like a plane) so that if you want to move the section view through the model, you can see the model more clearly without having that screen....??
thanks
thanks
RE: SECTION VIEW-REMOVING SECTION SCREEN
And there's no need to yell in your subject lines. We read 'em all.
-handleman, CSWP (The new, easy test)
Unfortunate there's no way to disable that... wonder if a request to SW would take notice... anyone else find that annoying?
Not me, I actually prefer the shaded mode.
