Need to get "Default" out of the QTY column of my BOM
Seriously, why does it even show up there.  I tried all the options for BOM on the Tools>Options but when i make a new BOM the Default still shows up.
SW2008 Office Pro SP3.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot/SpaceNavigator
RE: Need to get "Default" out of the QTY column of my BOM
just tried that but im still getting the configuration name as soon as i insert the new bom.
2.2GHz, 2.00GB RAM
QuadroFX 3700
Are you re-saving the template (or creating a new one) after applying the suggested option?
cheers
BOM template?
no im not doing anything with it.  the webpage linked doesnt say anything about messing with the template.
2.2GHz, 2.00GB RAM
QuadroFX 3700
Nope doesnt work.  Tried it with all those options checked on and off and nothing.  my sw is retarded.
2.2GHz, 2.00GB RAM
QuadroFX 3700
uGlay
Just had the same thing happen and cannot fix it as well. Other drawings from same format/template do not display config name before QTY in BOM??
Anyone?
Check the configuration info of the part in the assembly file.  I have put the part info under a configuration (configuration specific tab under properties) by accident instead of the custom tab before.  When you reference the part with that configuration the information on the configuration is grabbed.
No that's not it.
2.2GHz, 2.00GB RAM
QuadroFX 3700
In your BOM, go to the QTY column and change the title from Default/QTY.  to QTY
Notice that there should be no period after the QTY
Resave your BOM template.
Cheers,
Anna Wood
SW2008 SP4.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
Under tools/options/document properties/detailing/tables
check the box "restrict top level only boms to one configuration"
then make sure you're only using a top level only bom.
viola it's fixed.
James Spisich
Design Engineer, CSWP
Jspisich,
Are you sure that's viola and not cello?
cheers
The Restrict top level only BOMs to one configuration option is the only one that works for me; the method described at the link in my first post doesn't. (My apologies for not checking first)
See http://www.theswgeek.com/2008/06/27/creating-your-bom-template/ for the correct info on BOM options and templates.
hotiron
The config name will only appear if more than one config exists, or if the Default has been renamed ... in which case Default/QTY. will be shown ... go figure!
cheers
