swelling of polypropylene or polycarbonate
Thanks in advance, I'll try not to sound too stupid.
In past projects I've used heptane to swell silicone tubing before inserting the mating part. When the heptane evaporates the silicone shrinks again.
Does anyone know if there is a similar phenomenon for polycarbonate or polypropylene?
I have searched this forum, Googled, searched with GlobalSpec, gone through some books I have, etc. and found nothing on the subject.
If not, I'm looking at heating the outer part.
RE: swelling of polypropylene or polycarbonate
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
PP will swell in some hydrocarbons, but the reactions both ways will be very slow and not likely practical. Heat will soften PP to the extent it might easily snap over then shrink on, but to much heat or stretch will result in a permanent distortion.
Warm one and freeze the other part is the best advice I have seen or can think of.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
