Assembly section view
I am trying to exclude a few components from my assembly section view. The help section says that a list of components can be selected to be excluded, but i dont see anything in the section property manager nor do i get any pop-up to select components to be excluded...any suggestions?
Mike
Mike
RE: Assembly section view
-handleman, CSWP (The new, easy test)
http://www.EsoxRepublic.com-SolidWorks API VB programming help
I also wanted to know if there is a way to show the cosmetic thread in the drawing view...i can see it the part, but it does not show on the drawing.
Go to Tools > Options > Document Properties > Detailing - Annotations Display and select Display Annotations.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--"Coffee Talk" Mike Myers SNL
I'm a great believer in configs, but they should be used judiciously as they will increase file size.
Mechanical Designer
However, as you said, there is no right or wrong way. Just do it the way you find easiest or which best suits your company's procedure.
