shock spec for RFID tags on pipes
Just had a small question, I am hoping that you have come across this. Is there some kind of a shock / vibration frequency limit for electronics? Can we find a value like that in a spec for a device/component? And also if its a generic kind of value for all electronics (e.g. above 20g's and 1000Hz vibration frequency component x will fail) or a place where we can find such numbers?
I am actually looking at putting RFID tags on pipes and am tasked to write up a minimum spec for the tags. Any ideas on testing this would help too.
