Bringing an assembly coordinate system to individual part
Hi All,
If I have a component in an assembly, is there a quick way to create a new coordinate system at the component level such that the new coordinate system coincides with the assembly coordinate system?
RE: Bringing an assembly coordinate system to individual part
In the assembly, Analysis>-Measure>-Transform, and the pop-up box gives you your x,y & z values to create an offset co-ord system in the part. (Careful with the signs for each translation)
Kevin
"It is a mathematical fact that fifty percent of all doctors graduate in the bottom half of their class." ~Author Unknown
"If two wrongs don't make a right, try three." ~Author Unknown
