Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The enviroment is simple, natural and efficient. The members are competent, educated and professionals..."
Geography
daschneida (Mechanical)
29 Jul 08 16:48
I am working with some ground up ceramic with a particle size range under 100 microns with a peak at approximately 50 microns.  I am attempting to use this powder to make a ceramic coating.  Is it possible to make a suspended slurry with this particle size distribution?  If so, what additives tend to help with suspension?
Thanks for your help,
Daschneida
unclesyd (Materials)
2 Aug 08 21:41
A ceramic slurry is normally just a mixture of ceramic particles, an anionic dispersing agent, binder and solvent.
Look at the Ciba site for one of thousands of anionic agents. The binder could be as simple as Sodium Silicate. In most cases the solvent is water. There are other additives like antifoams, flocculating agents, and antibacterial additives. I don't about your particle size distribution, but my mother made ceramic slurry's from a lot native clays with very little separation.
http://www.ciba.com/index/ind-index/ind-paints_and_coatings/ind-pai_coa-tec-new/ind-paints_and_coatings_technologies_polymer/ind-paints_and_coatings_technologies_polymer_anionic-dispersion.htm
Check out the RR site on whats they offer. It might pay to give them a call.
http://www.ransom-randolph.com/ceramicshell/______deluxcote_concentrate.html
There are a lot books on Ceramics that have sections on making slurry's or slips. If I recall correctly my mother got here additives from a ceramic supply house.
AEH3 (Materials)
6 Aug 08 14:37
What do you mean by "ground up ceramic"?  What is the composition of the powder?  What characteristics do you need for your coating?
Helpful Member!  sreid (Electrical)
7 Aug 08 5:24
I believe with that size particle you will only be able to maintain a slurry with mechanical mixing.  Dispersants keep particles from clumping but at the limit, setling time in a stationary suspension depends on the terminal velocity of the particles.  The bigger the rock, the faster it sinks.
I use a commercial ceramic slurry for polishing with particle sizes from 1 to 5 microns and they tend to settle to the bottom of the tank over night.
7 Aug 08 14:18
AEH3:  We're looking at ground up alumina...
sreid:  Thanks for the particle size info.  That was helpful.
Also, that was a good link provided by unclesyd.
daschneida
Close Box
Join Eng-Tips® Today!
Join Us             Close
