Inserting new part in assembly
This might seem a newbee question, becaus i am one.
Fist I made sketch 'A' in the assy on the top plane. Then I created a plane 'nr1' parallel to the top plane. Now I want to create a new part on this plane 'nr1', using the sketch 'A' as template with the convert command. When creating a new part in an assy, you're prompted to choose a plane. I choose plane'nr1' witch is parallel to the top plan of the assy. So far so good.
Now when i edit the part, suddenly the top plan i did choose before has changed into the front plane.
Is my procedure incorrect or what is going on??
A little sorry for my english, its a little rusty.
SW2008SP4
SW2008SP4
RE: Inserting new part in assembly
I don't know if this is the correct way to do this but it seems to work for me. Maybe someone else has a better way.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
Dan
www.eltronresearch.com
Why i use top down assy:
When drawing knifes for the metal industies, there is alway a male and a female part. So I draw in the top plane of the assembly the basic form of the blade as a sketch (exp.: a radius). Now I make two planes extra, one for the upper knife an on for the bottom knife. Further I do insert part on one of the planes (exp.: upper knife) and with the convert command I select the sketch in the assembly. Same M.O. for the bottom knife.
In this way, when the radius changes shape or dimension, I only have to adjust the sketch in the major assembly and the parts are automaticaly updated withe the new shape or dimensions.
Until next problem...
Noxi
SW2008SP4
Nothing wrong with top down design. If you forget about Front/Top/Right planes, you have no problems. These planes are imaginery. SW used to call them Plane1/Plane2/Plane3.
Alex
