PDF IMAGE PROBLEMS
PDF IMAGE PROBLEMS
We are using NX5 in our drafting group. When one individual is exporting a multi-sheet drawing file as a pdf, occasionally it will create sheet 2 as yellow on a white background. We have tried to create the pdf of only sheet 2 and still have the same results, yellow on white. we want black on white. We renamed the sheet as something other than sheet 2 and get the same results.
I can create them with no problem. I have compared his pdf export settings and also customer default files with mine and they are identical.
Does anyone have a clue what the problem could be and also of course how to fix it?
Thanks in advance.
Thanks in advance.
Wayne Huseby
Drafter/Checker
Goodrich Corp
Jamestown, ND 58401
701-253-7799
RE: PDF IMAGE PROBLEMS
We still dont know why, but to allow us to create all black on white pdfs we first:
1. Created a new sheet,
2. moved the views from sheet 2 to the new sheet.
3. deleted sheet 2
4. renamed the new sheet to sheet 2.
results: all sheets created successfully in black.
Wayne Huseby
Drafter/Checker
Goodrich Corp
Jamestown, ND 58401
