VFD and short circuit
I'd like to know how does a VFD affect a short circuit level; two 7500hp motors (fed from 4.16kV, s/gear) are controled by VFDs. In case of the 3ph bolted fault at the gear, motors act as generators adding fault current at the bus. Having VFDs in series with motors, is there any change in fault generated at the bus (assumed motor run at full load)?
RE: VFD and short circuit
