Vacuum Pump Recomendations
7
I am looking for recommendations for liquid ring vacuum pump manufacturers.  I have a new project and I am new to this technology.  I'm trying to use vacuum distillation to reclaim / recycle plastic contaminated with a flammable oil.
RE: Vacuum Pump Recomendations
Have you googled "liquid ring vacuum pumps" yet?  I did it with the quotation marks and got 61,400 hits.  That will give you a start.
As far as a recommendation, hit #1 was Graham Manufacturing and I don't hesitate to recommend them.  www.graham-mfg.com
rmw
We used to use Nash liquid ring vacuum pumps but they may have been bought out by someone, maybe Graham.  They were quite serviceable.
Depending on how low you are going I would reccomend two other options.  First I would say that a dry screw pump from Kinney or Bush would be less of a problem.  The second option would be a eductor pump using condensate from your process as the motive fluid.   Works alot like the liquid ring pump but it gives you the option of multiple stages.
StoneCold.
I've had good experience with Nash and Sihi.  Sihi I thought was a little better.
wizz..
Tell us more...... don't make everyone guess....
What is the capacity and depth of vacuum for your application ?
What is the application?
This helps a lot in suggesting manufacturers.
-MJC
A word of caution: when sizing the pipeline to a vacuum pump double the water (liquid) flow to get the correct pipe size, most people forget that the air has to move too.  Using regular water flow rules at 6ft/sec will choke a vacuum pump.
Thanks All,  application is vacuum distilation to remove naphtha extrusion lube from PTFE film/tape.  Vessel is 600 cf and rated for 20 Torr.  I'm thinking liquid ring at the moment.
http://www.buschpump.com/
I have had very positive experiences with Busch, they know their strengths and limitations.
