Use of Shall, Should, May in formal documents etc.
I know this has been partially discussed before, such as in thread174-58057: "how to use SHALL or MUST" but I can't find a really good example of how these words are defined in contract documents etc. I looked in some of the ASME specs I have and didn't see them defined and I looked up MIL-STD-961D but they only define shall and not very succinctly.
I recall seeing good definitions in BAE Systems Statements of Work etc but no longer have an example
I'm writing an internal procedure and it's planned to be mandatory for some departments but only strongly recommended for others (don't ask) and I was thinking of using shall & may etc to identify this. I may avoid it altogether but I 'd still like to have a good example for future reference.
So if anyone can provide, or link to one, I'd appreciated it.
Quote (4.9.6):
h. "Shall", the emphatic form of the verb, shall be used throughout sections 3, 4, and 5 of the specification whenever a requirement is intended to express a provision that is binding. For example, in the requirements section, state that "The gauge shall indicate . . . " and in the test section, "The indicator shall be turned to zero, and 220 volts of alternating current shall be applied." For specific test procedures, the imperative form may be used, provided the entire method is preceded by "The following test shall be performed" or similar wording. Thus, "Turn the indicator to zero and apply 220 volts of alternating current." "Shall" shall not appear in sections 1, 2, or 6 of the specification.
i. "Will" may be used to express a declaration of purpose on the part of the Government. It may be necessary to use "will" in cases when simple futurity is required.
j. Use "should" and "may" whenever it is necessary to express nonmandatory provisions.
k. "Must" shall not be used to express a mandatory provision. Use the term "shall."
KENAT, probably the least qualified checker you'll ever meet...
RE: Use of Shall, Should, May in formal documents etc.
For a contractual document, the best thing to do is define the terms right in the document.
That would probably work for your (peculiar) case as well.
Just use "shall" everywhere and exempt the appropriate departments in the transmitting cover letter.
In the second and third person, shall is imperative, and will is not.
The nuances of English.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
C100 Verbal Forms
101 "Shall":Indicates requirements strictly to be followed in order to conform to this standard and from which no deviation is permitted.
102 "Should": Indicates that among several possibilities, one is recommended as particularly suitable, without mentioning or excluding others, or that a certain course of action is preferred but not necessarily required. Other possibilities may be applied subject to agreement.
103 "May": Verbal form used to indicate a course of action permissible within the limits of the standard.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I know what they mean generally & could look up a dictionary if I was unsure but I remembered seeing good contractual definitions before and wanted to see if anyone had good examples. I know there wont be a universal standard.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
You could be right. I was just parroting what I was taught, but that was about 50 years ago. A lot has changed in the language since then. Some for the better, some not, but that is only my opinion.
Shall / will are imperatives.
You will /shall advise any changes to the contract. You shall / will rectify any faults in construction.
Should is a suggested directive.
You should attend all site meetings.
May is a considered action.
If the contract is finalised prior to the contract date, you may request final payment.
It's a matter of issuing orders, rather than describing a desired state of affairs.
passive: The concrete shall be poured in 8" lifts.
AVIM: Pour the concrete in 8" lifts.
It's not 100% free of "shall" (or "must", which I think should be just as valid as "shall", and I really don't understand why people don't like it), but overall it makes for cleaner, more understandable language. One does need to define at the beginning of the document who the subject of the imperative is, though.
It's a hard sell for people who feel insecure without a lot of legal-sounding wordage.
Hg
I disagree about should, shall and must expressing the same degree of obligation.
That world is not my world.
In my world, "shall" is mandatory, and "should" means a desireable course of action.
But I also don't think answers.com is saying "shall" and "should" have the same degree of obligation. They both mention obligation, but obligation indeed has degrees.
I don't make a difference between "must" and "shall".
I had a South African supervisor who I think did make some kind of distiction between the two, though. He kept saying "you must" to me in situations that just didn't seem like he ought to be quite so imperative. I never really did get a good handle on exactly how he meant it.
Hg
Just to once again say that I know basically how to use them in everyday English (though I'm sure I often bend/break the rules with my sloppy grammar) and am as capable as anyone of looking them up in a dictionary etc.
My real question was in the specific context of contract documents, statments of work etc where I have seen definitions similar to what CoryPad gave.
As regards what you put HgTX, I have an issue with it from my field of Engineering documentation. I have always been taught to list requirements on Engineering drawings, requirement documents etc, not instructions, in fact the ASME standards for drawings at least say this. As such "The concrete shall be poured in 8" lifts." would be more correct to me than "Pour the concrete in 8" lifts." This appears to be the opposite of what AASHTO is telling you to do.
I've found that for a process-type specification with lots of actions, the active format works really well. Do this. Do that.
For something like a material specification where it's all about what something needs to *be*, it doesn't work as well. "Carbon content shall be <20%" doesn't translate well into imperative. Blind edicts to do everything one way or another inevitably result in awkwardness, since the natural language mixes both.
Hg
The problem with the statement above is that it seems to apply to all readers. Forward the spec to your boss for approval, and he is expected to perform the pour. Give the spec to prospective bidders, and all the prospective bidders (high, low, in between, no bid) are expected to pour. I believe making the concrete the subject rather than all the readers is the point of the passive voice tradition. Either that, or address the spec as a letter: "Dear winning bidder..."
Hg
However, on a drawing, I have always started each note with the verb in a command form such as:
"MASK ALL HOLES BEFORE PAINTING" or...
"MARK PART PER SPEC NO. ###-##-##" OR...
"PAINT PER MIL-P-#####"
I once had a vendor that read "PART WILL BE PAINTED PER MIL-P-###" and cleaned the parts then shipped them to us so that they could be painted. He thought we were just telling him what would happen next so that he would degrease them and so he proceeded to get them ready for whomever was going to paint them. That is why I use the command form at the beginning of each note.
Drawing specifies the requirements, for instance for your first example I'd say something like:
"HOLES TO BE FREE OF PAINT" this is the end result you want and something that can be inspected.
However, I know many people disagree.
I have been wording notes as shown above for years and never had a question from a vendor about our requirements.
Numerous specs suggest a standard sequence that attempts to match the chronological path of production as well:
1. MATERIAL
2. VARIOUS PROCESS REFERENCES/SPECS
3. HEAT TREAT SPECS
4. FINISH SPEC
5. MARKING SPEC
6. INSPECTION CRITERIA
7. PACKAGING SPEC
Ahh, the old logical order thing which ASME Y14.100 explicitly says you don't have to do but I tend to do because to me it makes the drawing clearer (I don't normally enforce it on others though).
I did just notice that 14.100 does define the use of should, shall & may for drawing notes (4.26.4 if anyone cares). Which would suggest to me that they are terms to be used on drawings, at least for mechancal items etc.
Good Night
I suspect order not being important is largely in 14.100 because of the way notes were edited in old manual drawings and the rules about not re-using notes identifiers etc. Having them roughly in order tends to make them easier to understand.
I agree about the standards generally setting a minimum standard. However here it's a minimum standard that most people still fail to meet by a mile.
" the word 'shall' is to be undertood as mandatory,
and the word 'should' as advisory.
The word "shall" indicates a requirement.
The word "should" indicates a recommendation.
Cuttie
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
In the second and third person, shall is imperative, and will is not."
I would suggest this isn't as true as it once was, but yes, this is a rule of thumb. However, general procedures and specifications should never be written in the 1st person. :)
Matt Lorono
Silicon Valley, CA
My problem with ASME's way of doing this is that they use dated language where they state requirements as matter of facts (don't use any shoulds, wills, shalls, mays). Some instructions are stated as being the case, without any clear directive.
Matt Lorono
Silicon Valley, CA
