Setting up a master template
Just curious, do I have to set a template for sizes A, B and C sheets or is there a way to set A and then copy across to B and C. I need inches and mm on each side so it would be six templates in all. The original people here have dozens all over the server and I want to standardize it.
RE: Setting up a master template
In SolidWorks, go to "Tools/Options/System Options/File Locations", go to drop down "Show folders for" and select 'Document Templates'. Select 'Add' and browse to the server location where the templates are located.
Select OK.
Follow same steps, except go to Tools/Options/System Options/Default Templates". Change 'Drawings' and browse to one of the standard templates used the most.
Same setting for all users. You could use Copy Settings Wizard and have each user use these settings, or use an admin image.
Several ways to do this.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
