adhesive shear allowable under torque
I'm having trouble thinking about how to come up with a ballpark allowable value for a bonded attachment under a torque load.
The attachment pad is circular and is bonded to a baseplate. The pad has a direct shear allowable of say 100lb. However, it is subjected to a force which will induce a rotation about the base giving rise to torque-shear in the adhesive.
Any ideas?
Any ideas?
RE: adhesive shear allowable under torque
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Also note that failure of the "test" article may not have been in the elastic region, so your answer may be off as well.
When in doubt, install some fasteners through that puppy :)
Nert
