transit bus recharging system
Hello
I am researching rechargable buses and hybrids that could top up power at bus stops. Intended for UK city routes. I am needing to identify charging equipment as well as resources on related schemes.
The charging rate may be as high as 200kw and presumably will be a 750volt charging system.
Thanks and regards
Thanks and regards
RE: transit bus recharging system
Maybe a short over head rack might work better. Or make that two or more for a complete circuit (I assume rubber tires).
Yes thats the upper ammount and it assumes charging 3+kwh at the stop in a single minute. From driver surveys and other sources the bus type I am researching would basically be at the stop one minute+, and the good thing is that as the bus is bus is filled it needs more power but will get more charging time. It will also have about 2 minutes minimum at the end of the route which should help spread demand a bit at some stops with some reserve.
The charging rate is only possible with the performance claims of the most leading edge batteries, unless much larger battery packs are used, but its a starting point, otherwise more stops can have chargers and the rate reduced a lot. I intend to model for only 10 or so charging stops on a typical transit route of 20km round trip.
Would you consider a means of swapping batteries instead and recharging the spares slowly? Maybe this requires more physical infrastrucutre.
If I recall correctly, the fastest electric car used "D" cell batterys because of the power density, and discharge capacity.
If heating is a problem, then a passive cooling system is possible. Maybe an aluminun rack, with some sort of cooling fins.
