Unequal Angle weldment wrong way round
Can't figure this one myself.
I am using unequal angles in a weldment.
The problem is, some angles won't rotate to the correct orientation
How does one do this.?
thanks
Howard
RE: Unequal Angle weldment wrong way round
Can you be a bit more specific?
How are you creating the weldments? How are you trying to rotate the pieces?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
OK,
I am inserting an unequal angle into a weldment.
Using a standard library weldment within Solidworks.
The angle is always orientated in a default direction.
I want it inserting opposite handed to this direction.
This isn't solved by rotation, or moving the location point.
The part profile is handed.
thanks
Howard
delete the line the profile is being extruded along and redraw it in the opposite direction.
cheers
In 2008 they introduced the option to mirror the profile. In previous versions I just used a LH and an RH version of the weldment profile. Be sure to keep the descriptions the same to enable grouping.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
What the Limey is suggesting should work.  Just delete your sketched line, and, instead of drawing it from A to B, draw it from B to A.  Then try inserting your weldment.
Dan
www.eltronresearch.com
