pH effluent in Secuencial Batch Reactor
Hi, i have problems in my wastewater plant:
The pH of effluent is near to 8.0, the pH feed to SBR is near to 6.5 and in the reaction phase have much white foam.
it is possible that the foam must to an excess of coagulant/floculant used in unit CAF, previos to SBR.
Water Analysis are:
Feed SBR=
Total solids: 2500 mg/L
Suspended solids: 800 mg/L
Oil and grease: 40 mg/L
BOD: 1200 mg/L
Q: 3 l/seg
Volume Water feed: 75 m3
Sludge=
Volatile Suspended solids: 2500 mg/L
Volume Sludge: 300 m3
Effluent=
Total Solids: 1600 mg/L
Suspended solids: 100 mg/L
Oil and grease: 20 mg/lt
BOD: 50 mg/Lt
NO2-: < 10mg/L
at the moment I am not measuring phosphorus and nitrogen not to have the reagents.
Thanks.
Manuel Argüelles
Venezuela.
Water Analysis are:
Feed SBR=
BOD: 1200 mg/L
Q: 3 l/seg
Sludge=
Effluent=
BOD: 50 mg/Lt
NO2-: < 10mg/L
Thanks.
Manuel Argüelles
Venezuela.
RE: pH effluent in Secuencial Batch Reactor
You need to check the F/M ratio to see if you are overfeeding the activated sludge process.
You also need to do a better job of removing the O/G.
Manuel Arguelles
Venezuela
