Hand rail embedded in concrete with sleeve
Does any one know where to find info / literature on designing an embedded railing post in concrete that has a sleeve? typically I have seen posts embedded 6 inch in concrete that has been core drilled with a grouted sleeve in the hole. Are there any guidelines as to minimum depth, or any design guidelines?
RE: Hand rail embedded in concrete with sleeve
Thanks, this is certainly a good starting point.
