lasers to check perpendicular movement
I know lasers are used to check how perpendicular the movement is for 2 axes on machine tools.  I just don't know how you set the laser up to measure this.  I understand how interferometry is used to measure a linear distance.  How do you use it to measure a perpendicular movement?
RE: lasers to check perpendicular movement
How does that work? Does the stationary beamsplitter have 2 outputs? One inline and one at 90 degrees?
