Recommendation for self locking nut with greatest removal resistance
Hi everyone,
I'm hoping someone having experience with self locking nuts can help with the following.
I need a self locking nut to be used on a 1/4-28 thread bolt. I'm not going to really torque the nut down, I'm just going to snug the nut down to take up any linear or axial play in the bolt.
The nut will actually "rotate with" the bolt as the bolt is rotated in order to adjust the position of a slider. There is a Delrin washer under the nut. The only thing that can really cause the nut to back-off would be if the friction between the nut and the Delrin washer during rotation, is greater than the torque required to loosen the lock nut.
Presently I'm using loc-tite and it works OK but I would like to see if I could just use a stock lock nut. The nut will never be reused or anything, basically just snugged down, set and forget. There are also no vibrations present.
I've listed the choices of lock nuts that I have from mcmaster carr below.
90566A210 (Nylon insert type Lock nut)
94830A515 (Expanding type lock nut)
91837A250 (Distorted thread type lock nut, top-lock style)
90040A120 (Distorted thread type lock nut, center-lock style)
Can anyone tell me which nut would provide the greatest resistance to removal with a standard wrench ?
Even if I have to keep using loc-tite, I might still use the lock nut since the locking feature of the nut could hold the nut in place while the loc-tite dries.
Loc-tite is good stuff but it just seemed that a self locking nut may be better from an assembly standpoint, and I won't have to wait for the loc-tite to dry.
Any feedback would be appreciated.
John
John
RE: Recommendation for self locking nut with greatest removal resistance
The distorted thread types will provide much higher resistance than the nylon insert or expanding type.
I recommend adhesives since they are strong and don't damage the mating part.
Are you having problems with the present curing time?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks for your reply.
Regarding your question, I have no real problems, I guess curing time could be reduced by heat as long as it doesn't get hot enough to hurt the Delrin washer under the nut.
I like loc-tite and adhesives as well, but it's just a matter of making sure the nut and bolt are clean, applying primer, applying the loc-tite, then waiting for it too dry.
I just thought if I could get a loc-nut to do the same thing it might be a better way to go from an assembly standpoint. From a strength and reliability standpoint, I really like loc-tite as long as it's applied correctly.
If I use a regular non hardened hex nut (maybe a grade 2 or a brass nut) could I tap a hole through the side (through one of the nut flats to the center of the nut) that would allow me to use a cone point set screw to lock the nut in place after it's snugged down, or would tapping the nut in this way mess up the nut threads so that it would not thread onto the bolt ?
If it could work, tapping the nut would be easy and set screws are cheap. Plus I would save time cleaning the bolts, applying primer, and waiting for the loc-tite to dry.
Once the cone point set screw digs in, I don't think it would go anywhere. It's just a matter of whether it can be done without messing up the nut threads.
Do you think it would it likely work ?
John
P.S. Regarding those distorted thread type locking nuts, does it matter if they are top lock or center lock style ?
Cory
If the adhesive is working, why change?
Any type of self-locking nut is intended to supplement the resistance to loosening developed by properly preloading the joint.
The resistance to rotation provided by the self-locking mechanism is typically only a few lb-inches for a 1/4-28 fastener. The actual value is readily available in the manufacturer's literature, or the controlling standard.
For maintaining a nut on a bolt used as a trunnion - as in your case - a castellated nut and cotter pin is generally the preferred method.
I've used both with very good results.
http://www.longlok.com/products_vibraseal.htm
http://www.nylok.com/products_precote85.htm
http:
http:
I will just drill a hole in the bolt at the proper position to receive a 1/6" OD cotter pin, and try to use the castle nut.
I'm not sure If I will be able to drill the grade 8 bolts I'm presently using so I may have to go to a softer bolt.
Thanks again guys,
John
This is because I can't have any axial play in the bolt and if I pre drill the hole in the bolt, then I may have to back off the castle nut a little to get the cotter pin to align with the hole.
If a distorted thread lock nut is not reliable enough, it looks like I will probably have to stick with loc-tite, go to a different faster drying adhesive, or tack weld it.
Using a lock nut and loc-tite together may be an option since the lock nut would just have to hold the nut in place while the loc-tite dries, then once the loc-tite dries it's not going anywhere.
I would also steer away from the double nut idea since your main issue is taking all the slop out of the joint. You can do this with two nuts, but it can take three hands.
I would recommend a standard nylock nut. I have never had one come off even in sever vibration applications. (of course your results may vary
ISZ
<historical note>
Before unit bearings came along, the automakers developed some fine- resolution variations on the castle nut, in larger sizes. If you had serious volume, maybe you could tool up something like that, say with a straight knurled nut and a castellated sleeve with an internal knurl.
There are also some variations on the Push-Nut that work on unthreaded rod, commonly used to hold wheels on garbage can axles. They work exactly once, just long enough to get through a short warranty. I hate 'em, but they're cheap, if that's an issue.
Mike Halloran
Pembroke Pines, FL, USA
B.E.
It's just a matter of how far off the misalignment between the hole and cotter pin will be but I think the cotter pin should have some give with a good wrench on the nut and bolt. A belleville washer under the nut would be added assurance.
I used some small 10-24 top-lock distorted thread lock nuts before and years ago I used some of the nylon insert lock nuts to hold a small engine down that had been vibrating loose.
One thing I remember is that the distorted thread top-lock nuts seemed to have some inconsistency as icestationzebra mentioned. The nylon insert nuts seemed more consistent with respect to back-off torque and much more re-usable although I'm not really concerned with re-usability.
This is not directly related to my problem but just out of curiosity, I have seen the comments from NASA which I think Mint Julep posted on split spring lock washer's, do you think that belleville washer's are better than split spring lock washers, or do they also (as NASA stated about the split spring lock washers ) basically have no locking ability once they are flattened by the nut ?
Berkshire, a shoulder bolt would certainly be cheap enough, but I'm not quite sure what you are proposing. The nut must rotate with the bolt as one unit as the bolt is rotated to adjust a slider.
A bolt is inserted through a clearance hole in a flat aluminum plate. The bolt head is on the bottom side of the .503" thick aluminum plate, the nut is on the top side of the aluminum plate. There is a .036" thick Delrin washer between the bolt head and the aluminum plate and the nut and the aluminum plate. The nut is snugged down just enough to take up any axial play in the bolt. There is 1/2" of thread protruding from the nut that is threaded into a slider. Rotating the bolt moves the slider. The bolt head and nut only serve to keep the bolt from translating axially as the bolt is rotated.
I'm currently using a # 91257A565 bolt from www.mcmaster.com.
Are you proposing that I use a shoulder bolt instead and just tighten the nut on the shoulder bolt until it bottoms out and then torque it down real good ? If that would work I would need to find a shoulder bolt with a 1/2" long shoulder and a 3/4" long threaded portion. I don't think that method would give me enough control to take up all of the axial play in the bolt and be consistent. That's one reason I did not use a C clip on the bolt, because I have to have zero axial play and the nut works good for that, plus the nut is strong and will never change due to axial loads.
The people doing the assembly are not crazy about the loc-tite method so I was trying to find a purely mechanical solution. Personally I like loc-tite as long as it's done right but I guess they feel the prep work and drying time are drawbacks.
I will just have to experiment until I find something I'm confident in. The nylon insert nuts would be great if they can be trusted. Otherwise, the castle nuts with a Belleville washer as a back-up may work.
Thanks again guys,
John
The castle nut gives you discrete adjustability which may not take all the axial play out of the joint. The installer has to decide when to install the pin. Could be loose, could be tight.
The bellville washer will not lock, it only provides a tension preload depending on how much it is compressed. This will axially load the joint which you want to freely move.
The split lock washer will not effectively lock until it is loaded tight. Then it will not allow the bolt to be rotated to move the slider.
Ted
http:
htt
John
Ted
you don't have to worry about backing off slightly to fit a castle nut, you don't have to switch to a lower grade bolt, you don't have to wait for drying time and if after some wear it needs readjusted it could be readjusted without a reduction in holding force.
If the nylon insert lock nuts work though, that would be the way to go.
I've never used two jam nuts for something like this and I was not sure if the technique would be reliable enough. I guess I kind of felt they might loosen up over time and I can't have that.
I used a jam nut technique a while back when I had to remove some threaded studs from an old water pump. The studs on the old pump had to be transferred to the new pump. These are the studs that hold the fan onto the pump and they have no head or anything to get a wrench on ( 4.3 V6 pickup engine).
I screwed two standard nuts on the stud, tightened them against each other, and then used the bottom nut to back the stud out.
Yes I was proposing getting a shoulder bolt the correct length and just screwing the nut down to the shoulder.
that was before I realised that you were making fine adjustments with the nuts.
To do what you want two AN316-4 half nuts should work just fine.
B.E.
I use four NAS 1/4-28 bolts to attach the mounting bracket assembly for my oil cooler. The mount is 'flexible' in that it has a white Delrin compression sleeve with Delrin washers under steel AN washers on each end of the bolt. I use a simple Nyloc nut on each 'snugged up' to allow some movement since this is a race car application with moderate to severe vibration potential. No failures in seven seasons.
Maintenance is frequent and although I re use the bolts, I always put on new nuts...That's cheap insurance.
Rod
I will probably give the nyloc nuts a try first.
Just out of curiosity, regarding the jam nut technique, would I be better off to use a right hand threaded nut and a left hand threaded nut together ?
If only one right hand threaded nut were used, then rotating the bolt in one direction would tend to tighten the nut and rotating the bolt in the other direction would tend to loosen the nut. If I put a left hand threaded nut on top of the right hand threaded nut and tighten them against each other, when the bottom right hand threaded nut tries to back off and loosen, it would immediately cause the top left hand threaded nut to tighten down.
Unless I'm missing something it seems using one left and thread and one right hand thread jam nut would almost be fool proof ?
John
I've had trouble with jam nuts in a similar situation but it maybe be because I wasn't using them correctly. There have been posts on hear before about jam nuts & how they work etc, worth looking for if you think it's a way to go.
KENAT, probably the least qualified checker you'll ever meet...
-handleman, CSWP (The new, easy test)
Unless I am misinterpreting something, I would like to see how you get a left hand and a right hand nut on a single threaded shaft. Right and left hand threads do not mix!!
Timelord
thread311-164764: Jam Nuts
thread725-188550: Double nutting?
thread725-57042: vibration proof fasteners
It is difficult to control the point at which the pair will lock up however.
One last thing occurred to me, it would be kind of overkill for me but may work well if someone else has a similar situation.
The Delrin washers could be replaced with needle or ball thrust bearings with steel thrust washers. This would allow the nut to be torqued down pretty good, and the bolt would still rotate easy. Even a regular non-locking nut would probably stay on pretty good with this method and the bolt could support high axial loads as the delrin washer is presently the weak point. Also, any problem with wear on the Delrin washers causing axial play would be eliminated.
In any event I suspect the nyloc nuts will be the best alternative to loc-tite.
Thanks and take care guys,
John
