atribute extraction
atribute extraction
atribute extraction
I'm back again with a question about attribute extraction. I tried using the attout, but I noticed that i don't get the device x,y corrdinates.Is there a code I can add to attout that will give me the corrdinates?
RE: atribute extraction
Try Eattext, it has a wizard to make it easy to customize the output.
____________________
Civil 3D 2008, Terramodel
I've tried it before and didn't like it to many options, I'm to get to the point were there is not that much info to manually enter.
Eattext has the options for coordinates,as does Attext.
