Dispersion of Surface Load
I have to design a tunnel that has a 50,000 lb load located over about 5' of compacted granular fill. Is there a reference that can be used for distributing the load laterally to reduce the effect of this on the roof? Also looking at using a geogrid material to help disburse the load. Is this normally cost effective?
any help appreciated, Dik
RE: Dispersion of Surface Load
Dik
