Font Problem Importing AutoCad Drawings into Solidworks
I'm having difficulty importing AutoCad .dwg files into SolidWorks. I have modified the data\drawfontmap.txt file as per my preferences (arial), but whenever I try to convert a .dwg file the fonts still appear as the default. I checked, and true type arial font is in my system folder. Is there some other setting somewhere I need to change for this to work? I am using SolidWorks 2007 SP 4.0 . I have attached the drawfontmap.txt file I am using. Thanks.
