Standard Aluminum profiles - dimensions
None of the books that I have seem to show things like corner rads (inside & out) on square or rectangular profiles is there an online resource or a rule that I can use to figure out what the values are? IE inside rad is a function of the wall thickness and uniform wall gives the outside rad.
Steve
RE: Standard Aluminum profiles - dimensions
Those dimensions are standardized in ANSI H35.2 Dimensional Tolerances for Aluminum Mill Products.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Do you have a copy of the Aluminum Design Manual from the Aluminum Association?
--Scott
http://wertel.eng.pro
No I don't have a copy, but I think I should dig one up. Thank you for the responses.
Stephen
