How can the volute casing of a centrifugal pump be designed
Supposing you have an impeller and you want to design the casing for the impeller how do you go about it? How do you get the size? what parameters determine the dimensions?
RE: How can the volute casing of a centrifugal pump be designed
"If everything seems under control, you're just not moving fast enough."
- Mario Andretti- When asked about transient hydraulics
http://virtualpipeline.spaces.msn.com
