Magnasium Oxide based Material Efflorensent problem
My company is making products from Magnasium based cement for out door ornament, but there is a efflorensent problem when we placed out out door after heavy rain. We tried apply water proof sealer for conrete on our products but it still doesn't do much good. it could be because the sealer are made for calcium based material which is why it doesn't work on our product. Anyone have a solution to our efflorensent problem? Any water proof sealer out there are particularly for Mabnasium Oxide based product?
thank you
thank you
RE: Magnasium Oxide based Material Efflorensent problem
However, the engineers that practice in geotechnical subjects also generally are associated with construction materials testing. One of the common construction problems is efflorescence on concrete block and brick walls, etc. It is quite likely that you will get some help there.
I suggest re-posting in the forum "Geotechnical Engineering other topics"
As for the efflorescence, I am not surprised, since you have an unstable compound that will easily convert to carbonate and hydroxide forms. As for a solution to the issue, you might try a sodium or potassium silicate sealer, or if you don't want a reactive sealer such as the silicates, you can use a methacrylate penetrating sealer.
Thank you every much for your answer.
As for your question, We never had any problem with expansion, as our products have done ASTM tests for thermal, and moist resistance.
Effloresce is really the only problem left for us.
thank you.
