Dynamic Graphing Utility
RE: Dynamic Graphing Utility
Somewhere I have some VBA code that allows you to move two cursors along the x-axis and zoom in between them.
Not nearly as slick as the Flash stuff in your link.
I have built a few different interactive graphs  for data in some of my spreadsheets.
One fairly simple one uses embedded chart and works primarily off the worksheet change event to change cells labeled Xmin, Xmax, Ymin, Ymax (which directly changes the chart limits).  Also a button for panning left/right by user-selectable amount and a toggle button for linear/log.
A more complicated one allows the user to select points.  But it's behavior seems a little flakey still.
Both are embedded in large spreadsheets. I will try to unbundle the simple one and post it this weekend.
Here is another version, with documentation slightly improved:
http://home.comcast.net/~electricpete/eng-tips/PlotInteractiveR3.xls
Thanks to joerd for helping me figure out how to scale the data for plotting, without creating another copy of the data.
electicpete-
Thanks for the chart. Its not exactly what I was looking for but it is really nice and will help me until I can find what I am looking for.
Thanks a bunch!
