Modeler Error: Calling KI before the previous call completes"
I am using NX3.. I am getting Error some thing like below one
"Hit OK to Continue
"Error recovery completed for the following error:
This is happening (while using Offset surface command)whenever I try to change parent of offset surface or try to select some more faces from same parent surface. After getting this error I can't continue the modeling, it force me close the UG and restart.
Please help me to rectify this problem.
Thanks for your repliessmile smile
Rafi
